Saltar al contenido principal
Durofix RV332 Battery Replacement
Qué necesitas
  1. Durofix RV332 Battery Replacement, Battery: paso 1, imagen 1 de 3 Durofix RV332 Battery Replacement, Battery: paso 1, imagen 2 de 3 Durofix RV332 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: paso 2, imagen 1 de 2 Durofix RV332 Battery Replacement: paso 2, imagen 2 de 2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: paso 3, imagen 1 de 1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
Conclusión
2 personas más completaron esta guía.
Brennan Wade
Miembro Desde 02/21/14
122 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 2,637
