Saltar al contenido principal
DualShock 4 CUH-ZCT1 Charging Port Replacement
Qué necesitas
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: paso 1, imagen 1 de 1
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 2, imagen 1 de 1
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 3, imagen 1 de 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 3, imagen 2 de 2
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 4, imagen 1 de 1
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 5, imagen 1 de 1
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 6, imagen 1 de 1
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 7, imagen 1 de 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: paso 7, imagen 2 de 2
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
Conclusión
7 personas más completaron esta guía.
Andy Lam
Miembro Desde 01/31/23
307 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 54
Ultimos 30 días: 259
Todo El Tiempo: 3,134
