Saltar al contenido principal
DualShock 4 CHU-ZCT2U Charging Port Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: paso 1, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: paso 1, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 2, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 2, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 2, imagen 3 de 3
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: paso 3, imagen 1 de 2 DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: paso 3, imagen 2 de 2
    • Pull the ribbon cable from the charge port, using a set of tweezers.
  4. DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 4, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 4, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 4, imagen 3 de 3
    • Grip the right hand corner of the opaque white piece with a pair of tweezers, and pull it upwards to remove it.
  5. DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 5, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 5, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 5, imagen 3 de 3
    • Lift the clear plastic piece up by its right hand corner.
    • Pull it to the right to remove the bottom left hand corner from the groove.
    • Remove the clear plastic piece. It pushes in easily.
  6. DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 6, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 6, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Port Replacement: paso 6, imagen 3 de 3
    • Peel off the black sticker on the charge port, using a pair of tweezers.
    • Unscrew the 4.50mm screw in the center of the port chip, using a Phillips-Head screwdriver.
    • Pull the charging port out with a pair of tweezers.
Conclusión
16 personas más completaron esta guía.
David Seale
Miembro Desde 10/09/17
1,630 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 Miembros
22 Guías creadas
9 comentarios
Came in handy, since it’s hard enough to fix a JDM-030. Thanks!
Sunset Shimmer - Contestar
Just did this on my JDM-030 (3rd generation DS4) as well. I would point out that the charge port for the JDM-030 (JDS-030?) looks slightly different and has more of a T-shape than the JDS-040, but aside from that, the instructions are functionally the same.
I will lastly add that having good tweezers is a must: the tweezers my jeweler’s drivers came with were crap and I had to go to the store to buy another pair. Make sure your equipment is solid before assembly.
Rob Barba - Contestar
Can The JDS 040 work in a controller that uses the JDS 030?
RandyH - Contestar
Tried to replace my usb port with a board that reads “1-981-33-31” from amazon. It was listed as JDS-40 and it does not work. In fact when plugged into a usb port on my laptop the ribbon cable gets noticeably hot but the controller will not power on.
Devin Sidell - Contestar
Got the same problem. Any idea?
Jacco Veldscholten -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 13,156
