Saltar al contenido principal
DualShock 4 CHU-ZCT2U Charging Assembly Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): paso 1, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): paso 1, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): paso 1, imagen 3 de 3
    • Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
    • Place the removed screws to the side.
  2. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 2, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 2, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 2, imagen 3 de 3
    • Detach the top frame from the bottom frame by carefully pulling them apart.
  3. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 3, imagen 1 de 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 3, imagen 2 de 2
    • Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
  4. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 4, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 4, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 4, imagen 3 de 3
    • Take the bottom part (the side without the battery).
    • Remove the white plastic cover which is on the top of the Charging assembly.
  5. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 5, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 5, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 5, imagen 3 de 3
    • Remove the plastic cover which is in front of the Charging assembly.
    • Remove the transparent plastic cover which is on top of the Charging assembly.
    • Be careful while removing all plastic covers since they are very delicate and can break if removed forcefully.
  6. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 6, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 6, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 6, imagen 3 de 3
    • Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together.
    • Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame.
    • Take out the charging assembly chip.
  7. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 7, imagen 1 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 7, imagen 2 de 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: paso 7, imagen 3 de 3
    • Remove the white ribbon cable from the charging assembly chip.
    • Replace the Charging assembly chip with a new one.
Conclusión
If you have followed all the steps correctly, your LED Light should light up once you reassemble and plug your device to a USB cord. To reassemble your device, follow these instructions in reverse order.
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 3,054
