Saltar al contenido principal
DualShock 4 CHU-ZCT2U Buttons Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: paso 1, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: paso 1, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Buttons Replacement: paso 2, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 2, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 2, imagen 3 de 3
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: paso 3, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: paso 3, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: paso 3, imagen 3 de 3
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Buttons Replacement: paso 4, imagen 1 de 2 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 4, imagen 2 de 2
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Buttons Replacement: paso 5, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 5, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 5, imagen 3 de 3
    • Unhook the battery case from the motherboard, and pull it off.
  6. DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: paso 6, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: paso 6, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: paso 6, imagen 3 de 3
    • Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
  7. DualShock 4 CHU-ZCT2U Buttons Replacement: paso 7, imagen 1 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 7, imagen 2 de 3 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 7, imagen 3 de 3
    • Remove the rubber pads that secure the buttons in place for the arrow buttons, shape buttons, and Playstation Home button.
    • Do not turn the front shell cover upside down after completing this step, because some of the buttons may fall out.
  8. DualShock 4 CHU-ZCT2U Buttons Replacement: paso 8, imagen 1 de 2 DualShock 4 CHU-ZCT2U Buttons Replacement: paso 8, imagen 2 de 2
    • Remove the old buttons, and replace them with new ones using a pair of tweezers.
Conclusión
41 personas más completaron esta guía.
Michelle Joseph
Miembro Desde 10/09/17
1,762 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 Miembros
22 Guías creadas
2 comentarios
Where can I buy cuh zct2e spares from please
Paramdeep Dhaliwal - Contestar
Can’t see an updated guide, and this one worked perfectly fine. Used to replace the buttons on a knock-off DualShock 4 from AliExpress. Construction was largely the same, only devoid of a screw anchoring the battery cradle. Would argue this was an extremely easy repair!
Casey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 99
Ultimos 30 días: 339
Todo El Tiempo: 27,951
