Saltar al contenido principal
Drumset Head Replacement
  1. Drumset Head Replacement, Head: paso 1, imagen 1 de 1
    • Loosen the bolts around the drum rim with a Gibraltar Standard drum key.
  2. Drumset Head Replacement: paso 2, imagen 1 de 1
    • Carefully remove the rim from the drum base.
  3. Drumset Head Replacement: paso 3, imagen 1 de 1
    • Take the drum head out of the rim.
  4. Drumset Head Replacement: paso 4, imagen 1 de 1
    • Replace the old head with a new head.
  5. Drumset Head Replacement: paso 5, imagen 1 de 1
    • Gently rub the top of the drum base to remove the any extra pieces that may have fallen from the old drumhead.
  6. Drumset Head Replacement: paso 6, imagen 1 de 1
    • Use the Gibraltar Standard drum key to screw back in the bolts.
Linea de Meta
Steven Richard
Miembro Desde 02/24/21
1 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 199
