Saltar al contenido principal
Droid Ultra XT1080 Screen Replacement
Qué necesitas
  1. Droid Ultra XT1080 Screen Replacement, Screen: paso 1, imagen 1 de 3 Droid Ultra XT1080 Screen Replacement, Screen: paso 1, imagen 2 de 3 Droid Ultra XT1080 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Gently remove SIM card tray from device using a metal spudger.
  2. Droid Ultra XT1080 Screen Replacement: paso 2, imagen 1 de 1
    • After SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your way around the device until all the clips are undone.
    • Be gentle with the plastic to make sure it doesn't crack or break.
  3. Droid Ultra XT1080 Screen Replacement: paso 3, imagen 1 de 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Screen Replacement: paso 4, imagen 1 de 2 Droid Ultra XT1080 Screen Replacement: paso 4, imagen 2 de 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Screen Replacement: paso 5, imagen 1 de 2 Droid Ultra XT1080 Screen Replacement: paso 5, imagen 2 de 2
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Screen Replacement: paso 6, imagen 1 de 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Screen Replacement: paso 7, imagen 1 de 2 Droid Ultra XT1080 Screen Replacement: paso 7, imagen 2 de 2
    • Once motherboard is removed you have successfully removed the screen from the device.
Conclusión
knoyes
Miembro Desde 10/30/18
785 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 719
