Saltar al contenido principal
Droid Ultra XT1080 Charging Port Replacement
Qué necesitas
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: paso 1, imagen 1 de 1
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: paso 2, imagen 1 de 1
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: paso 3, imagen 1 de 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: paso 4, imagen 1 de 2 Droid Ultra XT1080 Charging Port  Replacement: paso 4, imagen 2 de 2
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: paso 5, imagen 1 de 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: paso 6, imagen 1 de 1
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: paso 7, imagen 1 de 2 Droid Ultra XT1080 Charging Port  Replacement: paso 7, imagen 2 de 2
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: paso 8, imagen 1 de 1
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Conclusión
Una persona más ha completado esta guía.
knoyes
Miembro Desde 10/30/18
785 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 850
