Saltar al contenido principal
Droid Ultra XT1080 Battery Replacement
Qué necesitas
  1. Droid Ultra XT1080 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: paso 2, imagen 1 de 1
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: paso 4, imagen 1 de 2 Droid Ultra XT1080 Battery Replacement: paso 4, imagen 2 de 2
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: paso 5, imagen 1 de 1
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: paso 7, imagen 1 de 2 Droid Ultra XT1080 Battery Replacement: paso 7, imagen 2 de 2
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: paso 8, imagen 1 de 1
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
Conclusión
3 personas más completaron esta guía.
knoyes
Miembro Desde 10/30/18
785 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 3,004
