Saltar al contenido principal
Drill Master Heat Gun Heating Coil Replacement
Qué necesitas
  1. Drill Master Heat Gun Heating Coil Replacement, Heating Coil: paso 1, imagen 1 de 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Heating Coil Replacement: paso 2, imagen 1 de 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Heating Coil Replacement: paso 3, imagen 1 de 3 Drill Master Heat Gun Heating Coil Replacement: paso 3, imagen 2 de 3 Drill Master Heat Gun Heating Coil Replacement: paso 3, imagen 3 de 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Heating Coil Replacement: paso 4, imagen 1 de 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Heating Coil Replacement: paso 5, imagen 1 de 1
    • Remove the plastic casing from the end of the barrel.
  6. Drill Master Heat Gun Heating Coil Replacement: paso 6, imagen 1 de 1
    • Remove the metal casing from the heating element.
  7. Drill Master Heat Gun Heating Coil Replacement: paso 7, imagen 1 de 1
    • Slowly remove the heat resistant wrapping from the heating element.
    • Be careful here - the wrapping can be easily torn!
  8. Drill Master Heat Gun Heating Coil Replacement: paso 8, imagen 1 de 2 Drill Master Heat Gun Heating Coil Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    $3.99
    Comprar
    • Use the angled tweezers to remove the heating coil end from the input point.
  9. Drill Master Heat Gun Heating Coil Replacement: paso 9, imagen 1 de 1
    • Remove the heating coil by unraveling it from the heating element.
    • To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
Conclusión
2 personas más completaron esta guía.
3 comentarios
Where are the heating coil wires found?
Thomas Frye - Contestar
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 56
Todo El Tiempo: 4,259
