Saltar al contenido principal
Drill Master Heat Gun Fan Replacement
Qué necesitas
  1. Drill Master Heat Gun Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Fan Replacement: paso 2, imagen 1 de 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Fan Replacement: paso 3, imagen 1 de 3 Drill Master Heat Gun Fan Replacement: paso 3, imagen 2 de 3 Drill Master Heat Gun Fan Replacement: paso 3, imagen 3 de 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Fan Replacement: paso 4, imagen 1 de 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Fan Replacement: paso 5, imagen 1 de 1
    • Remove the metal casing and fan cover from the fan unit.
  6. Drill Master Heat Gun Fan Replacement: paso 6, imagen 1 de 1
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
  7. Drill Master Heat Gun Fan Replacement: paso 7, imagen 1 de 1
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
  8. Drill Master Heat Gun Fan Replacement: paso 8, imagen 1 de 1
    • Remove the fan by pulling it from the motor rod and replace.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 2,436
