Saltar al contenido principal
Drift HD 720 Microphone Replacement
Qué necesitas
  1. Drift HD 720 Microphone Replacement, Battery: paso 1, imagen 1 de 2 Drift HD 720 Microphone Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: paso 2, imagen 1 de 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: paso 3, imagen 1 de 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: paso 4, imagen 1 de 1
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: paso 5, imagen 1 de 1
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: paso 6, imagen 1 de 1
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
Conclusión
Equipo
Baylor, Team 10-16, Williams Fall 2015 Miembro de Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 343
