Saltar al contenido principal
Drift HD 720 LCD Screen Replacement
Qué necesitas
  1. Drift HD 720 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Drift HD 720 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the back case from camera body.
  5. Drift HD 720 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Use J0 Phillips head to remove two 6mm long Phillips head screws from the motherboard.
  7. Drift HD 720 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the motherboard (green) from the front case housing.
  8. Drift HD 720 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Use the J0 Phillips head screws to remove two 5mm long Phillips head screws from the plastic bracket holding LCD in place.
  9. Drift HD 720 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Remove the LCD screen from the front cover.
  10. Drift HD 720 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Slide the black bar toward the LCD screen in order to remove the screen from slot.
  11. Drift HD 720 LCD Screen Replacement: paso 11, imagen 1 de 1
    • Remove the LCD from motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
Baylor, Team 10-16, Williams Fall 2015 Miembro de Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Miembros
8 Guías creadas
4 comentarios
Did you now where to find the replacement LCD screen? Thanks.
Rodrigo Forrequi - Contestar
I believe eBay should work.
Ruru Idahosa - Contestar
need a ribbon for stealth 2 any ideas?
dennis - Contestar
Good job! That guide indeed helped me a lot to give my Drift HD a good cleaning. Was a bit tough to remove the PCB, but after some fiddling it worked. Should be mentioned that you can remove the microphone from the surrounding rubber gasket so you can wash the gasket with ordinary soap. You can also separate the two PCBs (they are just stacked ontop of earch other using press-fit connectors)for easier access, e. g. if you want to clean and re-grease the collar of the lens unit. Also keep an eye on the aluminum cooler star. It has some heat conduction compond on it that you want to spread evenly. Don't wash it off entirely!
Volker Bartheld - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,114
