Saltar al contenido principal
Dress Shirt Button Replacement
Qué necesitas
  1. Dress Shirt Button Replacement, Button: paso 1, imagen 1 de 2 Dress Shirt Button Replacement, Button: paso 1, imagen 2 de 2
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: paso 2, imagen 1 de 3 Dress Shirt Button Replacement: paso 2, imagen 2 de 3 Dress Shirt Button Replacement: paso 2, imagen 3 de 3
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: paso 3, imagen 1 de 2 Dress Shirt Button Replacement: paso 3, imagen 2 de 2
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: paso 4, imagen 1 de 3 Dress Shirt Button Replacement: paso 4, imagen 2 de 3 Dress Shirt Button Replacement: paso 4, imagen 3 de 3
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: paso 5, imagen 1 de 1
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: paso 6, imagen 1 de 3 Dress Shirt Button Replacement: paso 6, imagen 2 de 3 Dress Shirt Button Replacement: paso 6, imagen 3 de 3
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: paso 7, imagen 1 de 3 Dress Shirt Button Replacement: paso 7, imagen 2 de 3 Dress Shirt Button Replacement: paso 7, imagen 3 de 3
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
Conclusión
Your shirt is now ready to be worn again.
Una persona más ha completado esta guía.
Jonathan Wong
Miembro Desde 04/09/15
198 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-4, Green Spring 2015 Miembro de Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 34
Todo El Tiempo: 3,796
