Saltar al contenido principal
Dremel MultiPro 395 Casing Replacement
Qué necesitas
  1. Dremel MultiPro 395 Casing Replacement, Casing: paso 1, imagen 1 de 2 Dremel MultiPro 395 Casing Replacement, Casing: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: paso 2, imagen 1 de 2 Dremel MultiPro 395 Casing Replacement: paso 2, imagen 2 de 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: paso 3, imagen 1 de 2 Dremel MultiPro 395 Casing Replacement: paso 3, imagen 2 de 2
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: paso 4, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 4, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 4, imagen 3 de 3
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: paso 5, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 5, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 5, imagen 3 de 3
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: paso 6, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 6, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 6, imagen 3 de 3
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Casing Replacement: paso 7, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 7, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 7, imagen 3 de 3
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: paso 8, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 8, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 8, imagen 3 de 3
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: paso 9, imagen 1 de 3 Dremel MultiPro 395 Casing Replacement: paso 9, imagen 2 de 3 Dremel MultiPro 395 Casing Replacement: paso 9, imagen 3 de 3
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Conclusión
2 personas más completaron esta guía.
Un comentario
A link to parts is always nice,
bari - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 2,144
