Saltar al contenido principal
Dremel 8200 Disassembly
Qué necesitas
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: paso 1, imagen 1 de 2 Dremel 8200 Disassembly, Dremel 8200 Disassembly: paso 1, imagen 2 de 2
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: paso 2, imagen 1 de 2 Dremel 8200 Disassembly: paso 2, imagen 2 de 2
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: paso 4, imagen 1 de 1
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: paso 6, imagen 1 de 2 Dremel 8200 Disassembly: paso 6, imagen 2 de 2
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: paso 7, imagen 1 de 1
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: paso 8, imagen 1 de 2 Dremel 8200 Disassembly: paso 8, imagen 2 de 2
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
Conclusión
3 personas más completaron esta guía.
2 comentarios
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Contestar
How do you replace just the bearing in this assembly?
Andre Da Silva - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 44
Todo El Tiempo: 3,536
