Saltar al contenido principal
Dremel 4000 Shaft Lock Pin Replacement
Qué necesitas
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: paso 1, imagen 1 de 2 Dremel 4000 Shaft Lock Pin Replacement, Back Case: paso 1, imagen 2 de 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Shaft Lock Pin Replacement: paso 2, imagen 1 de 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Shaft Lock Pin Replacement: paso 3, imagen 1 de 2 Dremel 4000 Shaft Lock Pin Replacement: paso 3, imagen 2 de 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Shaft Lock Pin Replacement: paso 4, imagen 1 de 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Shaft Lock Pin Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Shaft Lock Pin Replacement: paso 6, imagen 1 de 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: paso 7, imagen 1 de 1
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
Conclusión
2 personas más completaron esta guía.
John Cobb
Miembro Desde 01/20/16
1,719 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 15-4, Remmell Spring 2016 Miembro de USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Miembros
13 Guías creadas
2 comentarios
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Contestar
three years later and I came to the same conclusion: DUH
Randy Martin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 32
Ultimos 30 días: 141
Todo El Tiempo: 12,385
