Saltar al contenido principal
Dremel 4000 Electrical Assembly Replacement
Qué necesitas
  1. Dremel 4000 Electrical Assembly Replacement, Back Case: paso 1, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement, Back Case: paso 1, imagen 2 de 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Electrical Assembly Replacement: paso 2, imagen 1 de 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Electrical Assembly Replacement: paso 3, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Electrical Assembly Replacement: paso 4, imagen 1 de 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Electrical Assembly Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Electrical Assembly Replacement: paso 6, imagen 1 de 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Electrical Assembly Replacement, Power Cord: paso 7, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement, Power Cord: paso 7, imagen 2 de 2
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Electrical Assembly Replacement: paso 8, imagen 1 de 1
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Electrical Assembly Replacement: paso 9, imagen 1 de 1
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Electrical Assembly Replacement: paso 10, imagen 1 de 1
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
  11. Dremel 4000 Electrical Assembly Replacement, Bearing Assembly: paso 11, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement, Bearing Assembly: paso 11, imagen 2 de 2
    • Carefully pull up on the shaft to lift out of the casing.
  12. Dremel 4000 Electrical Assembly Replacement: paso 12, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement: paso 12, imagen 2 de 2
    • Firmly hold the field assembly in one hand and the bearing assembly in the other.
    • Carefully slide the bearing assemble out of the field assembly.
  13. Dremel 4000 Electrical Assembly Replacement, Electrical Assembly: paso 13, imagen 1 de 2 Dremel 4000 Electrical Assembly Replacement, Electrical Assembly: paso 13, imagen 2 de 2
    • Firmly hold the field assembly in one hand, and carefully pull free the red and black wires that connects the electrical assembly to the field assembly.
    • Take note which slot gets the red wire and which gets the black wire for proper reassembly.
  14. Dremel 4000 Electrical Assembly Replacement: paso 14, imagen 1 de 1
    • This is your completely removed electrical assembly.
Conclusión
25 personas más completaron esta guía.
John Cobb
Miembro Desde 01/20/16
1,689 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 15-4, Remmell Spring 2016 Miembro de USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Miembros
13 Guías creadas
14 comentarios
One of the brush holders has a component...small capacitor... ten cent part. If somebody can identify the value of the component, I could fix mine now that I've replaced the control board and still won't start. I shorted across the component and suddenly came to life.
Tom Hartsell - Contestar
DF110S 110c Thermal Fuse 16A 250V
“Thermal fuse DF is an one shot device, after operating function have to be replaced.”
Jozef Kutej -
Anyone with info about the third wire (on mine is blue ending with a small copper clip) serves? This is connected off of the switch, labeled W5 on the circuit board. [Edit. It is a ground] I suspect it is a feed back wire for speed sensor? But where does it attach? Some wear on the abovementioned capacitor crossing one of the brushes. Anny ideas?
Mercedes Joy - Contestar
You see the copper bushing slot at the top of the picture (next to the guy’s index finger) from step 9? Directly underneath it where the slot sits, there’s a tiny notch in the gray frame. Once you pull off the bushing slot from the frame (if you haven’t already), slide the small copper clip (from your 3rd blue wire) onto that notch. Then you push the bushing slot back onto the frame where it was. Essentially, the copper clip is “grounded” to that bushing slot.
louisloria -
An even better photo in step 11 showing the copper clip on the blue wire located beneath the copper brush holder
D Lee -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 86
Ultimos 30 días: 326
Todo El Tiempo: 32,730
