Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dreamer Autoshade Motor Set Screw Adjustment
Qué necesitas
  1. Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: paso 1, imagen 1 de 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: paso 1, imagen 2 de 2
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
    Pregunta a FixBot
  2. Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: paso 2, imagen 1 de 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: paso 2, imagen 2 de 2
    • Using a flathead screwdriver, pry the bearing cap from the tube.
    Pregunta a FixBot
  3. Dreamer Autoshade Motor Set Screw Adjustment, Tighten Motor Set Screw: paso 3, imagen 1 de 1
    • Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • The hub should fit snugly on the shaft, unable to rotate freely.
    • Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
    Pregunta a FixBot
Conclusión
David
Miembro Desde 11/11/20
734 Reputación
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 38
Todo El Tiempo: 348
