Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dreamer Autoshade Idle Tube Length Adjustment
  1. Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: paso 1, imagen 1 de 2 Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: paso 1, imagen 2 de 2
    • Before adjusting the size of your tube, make sure you try adjusting the left side mounting nub. This guide is meant for users whose idle tubes are too long to fit after attempting to fit with the left-hand nub adjusted.
    • Measure the amount needed to remove in order to fit the shade in the wall mounts.
    • Measure and mark the distance needed to remove. Repeat this process to draw a circle around the entire tube.
    Pregunta a FixBot
  2. Dreamer Autoshade Idle Tube Length Adjustment, Shorten tube: paso 2, imagen 1 de 1
    • Use a sander, hacksaw, or appropriate metal cutoff saw to shorten the tube to the desired length. Be sure to use the required safety procedures for your chosen method.
    Pregunta a FixBot
  3. Dreamer Autoshade Idle Tube Length Adjustment, Replace left bearing cap: paso 3, imagen 1 de 1
    • Replace the bearing cap and nub on the left side of the shade tube.
    Pregunta a FixBot
Conclusión
David
Miembro Desde 11/11/20
734 Reputación
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 36
Todo El Tiempo: 348
