Saltar al contenido principal
Dreamax DMX-ST7A Motherboard Replacement
Qué necesitas
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: paso 3, imagen 1 de 2 Dreamax DMX-ST7A Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: paso 4, imagen 1 de 1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: paso 6, imagen 1 de 2 Dreamax DMX-ST7A Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: paso 7, imagen 1 de 2 Dreamax DMX-ST7A Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: paso 8, imagen 1 de 2 Dreamax DMX-ST7A Motherboard Replacement: paso 8, imagen 2 de 2
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: Cómo soldar y desoldar conexiones
Conclusión
Una persona más ha completado esta guía.
Stacey Mattila
Miembro Desde 03/18/15
543 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-4, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-4, Lauer Spring 2015
MTU-LAUER-S15S1G4
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 306
