Saltar al contenido principal
Dragon Touch Y88X Plus Motherboard Replacement
Qué necesitas
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: paso 3, imagen 1 de 1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: paso 4, imagen 1 de 2 Dragon Touch Y88X Plus Motherboard Replacement: paso 4, imagen 2 de 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently lift the motherboard from the device.
Conclusión
2 personas más completaron esta guía.
Cody Camara
Miembro Desde 11/01/23
149 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 68
