Saltar al contenido principal
Dragon Touch A1x Plus Battery Replacement
Qué necesitas
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: paso 2, imagen 1 de 2 Dragon Touch A1x Plus Battery  Replacement: paso 2, imagen 2 de 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: paso 3, imagen 1 de 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: paso 4, imagen 1 de 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: paso 6, imagen 1 de 2 Dragon Touch A1x Plus Battery  Replacement: paso 6, imagen 2 de 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Conclusión
Josh Null
Miembro Desde 03/21/18
313 Reputación
3 Guías creadas
Equipo
IUPUI, Team S5-G5, Baechle Spring 2018 Miembro de IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Miembros
6 Guías creadas
Un comentario
where can you find a replacement battery for this tablet?
Lupe Rdrgz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 1,827
