Saltar al contenido principal
Dopo Double Power 7 Speaker Replacement
Qué necesitas
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: paso 1, imagen 1 de 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: paso 3, imagen 1 de 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: paso 4, imagen 1 de 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
Conclusión
Una persona más ha completado esta guía.
mike pelosi
Miembro Desde 10/30/15
682 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 173
