Introducción
Use this guide to replace the motherboard in your Dopo Double Power 7.
Having a functioning motherboard is crucial because it is the component that holds all of the hardware that allows your device to work such as storage devices, the processor, and the power supply.
If you are experiencing problems such as no power, random errors, or crashes you may need to replace the motherboard of your Dopo Double Power.
A skill you may need for this repair is soldering.
Qué necesitas
The rear panel is secured to the front case and can simply be pried apart without damage.
Una persona más ha completado esta guía.
