Saltar al contenido principal
Dopo Double Power 7 Camera Replacement
Qué necesitas
  1. Dopo Double Power 7 Camera Replacement, Rear Panel: paso 1, imagen 1 de 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Camera Replacement: paso 2, imagen 1 de 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Camera Replacement: paso 3, imagen 1 de 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Camera Replacement: paso 4, imagen 1 de 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Camera Replacement, Camera: paso 5, imagen 1 de 1
    • Remove any black static tape that may be covering the motherboard.
  6. Dopo Double Power 7 Camera Replacement: paso 6, imagen 1 de 2 Dopo Double Power 7 Camera Replacement: paso 6, imagen 2 de 2
    • The camera is taped in place.
    • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
    • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
    • Simply, pull back the tape and remove the camera.
Conclusión
Una persona más ha completado esta guía.
mike pelosi
Miembro Desde 10/30/15
682 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 164
