Saltar al contenido principal
Door Stop Replacement
Qué necesitas
  1. Door Stop Replacement, Door Stop: paso 1, imagen 1 de 3 Door Stop Replacement, Door Stop: paso 1, imagen 2 de 3 Door Stop Replacement, Door Stop: paso 1, imagen 3 de 3
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: paso 2, imagen 1 de 3 Door Stop Replacement: paso 2, imagen 2 de 3 Door Stop Replacement: paso 2, imagen 3 de 3
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: paso 3, imagen 1 de 2 Door Stop Replacement: paso 3, imagen 2 de 2
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: paso 4, imagen 1 de 3 Door Stop Replacement: paso 4, imagen 2 de 3 Door Stop Replacement: paso 4, imagen 3 de 3
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: paso 5, imagen 1 de 3 Door Stop Replacement: paso 5, imagen 2 de 3 Door Stop Replacement: paso 5, imagen 3 de 3
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: paso 6, imagen 1 de 2 Door Stop Replacement: paso 6, imagen 2 de 2
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: paso 7, imagen 1 de 3 Door Stop Replacement: paso 7, imagen 2 de 3 Door Stop Replacement: paso 7, imagen 3 de 3
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: paso 8, imagen 1 de 3 Door Stop Replacement: paso 8, imagen 2 de 3 Door Stop Replacement: paso 8, imagen 3 de 3
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: paso 9, imagen 1 de 2 Door Stop Replacement: paso 9, imagen 2 de 2
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: paso 10, imagen 1 de 3 Door Stop Replacement: paso 10, imagen 2 de 3 Door Stop Replacement: paso 10, imagen 3 de 3
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Conclusión
Khoa Bui
Miembro Desde 09/20/20
198 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 82
Todo El Tiempo: 3,232
