Introducción
If you ever had a dome cover light fixture that that would not come off then this is the right guide for you. These lights are designed in a way that makes them so hard to take out in order to avoid risk of falling below. This being said the struggle of trying to change a light bulb has never been harder in any other light making people just give up or break the lamp cover in the result of trying attempting to remove it for so long. In this guide I’m going to show user exactly how to take off one of these covers and change their light to avoid dimness and darkness due to not being able to turn on the lights. My #1 tip before starting this project is to be patient, as the light will come off even if it’s not right away.
For home maintenance projects that use electricity from a circuit breaker, always turn off the power from the circuit breaker and turn off any light switches that provide power to the item you’re working on.
Qué necesitas
Gently turn the light in a counterclockwise direction with a gloved hand.
When the light starts moving enough, spin the light counterclockwise with the glove until it comes off.
2 comentarios
Thank you so much for your great instructions! I had tried twisting both clockwise and counter clockwise to get to the bulbs, but was afraid of breaking it because it is twisted on so tight. Now that I found your instructions, I will apply a bit more elbow grease.
Thanks again!
