Saltar al contenido principal
Dodge Durango 2004 Tail Light Bulb Replacement
Qué necesitas
  1. Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: paso 1, imagen 1 de 2 Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: paso 1, imagen 2 de 2
    • Open the car's trunk.
  2. Dodge Durango 2004 Tail Light Bulb Replacement: paso 2, imagen 1 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 2, imagen 2 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 2, imagen 3 de 3
    • Pry both caps out using a spudger.
  3. Dodge Durango 2004 Tail Light Bulb Replacement: paso 3, imagen 1 de 1
    • Carefully pull the tail light towards yourself to gain access to the wiring.
    • Do not pull the tail light too far. It is still connected to the wires and moving it too far may damage them.
  4. Dodge Durango 2004 Tail Light Bulb Replacement: paso 4, imagen 1 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 4, imagen 2 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 4, imagen 3 de 3
    • Locate the connector and pull the orange safety pin out.
    • After the safety pin is out, pull on the connector plug to separate it from the tail light.
  5. Dodge Durango 2004 Tail Light Bulb Replacement: paso 5, imagen 1 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 5, imagen 2 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 5, imagen 3 de 3
    • Remove the three Torx 15 screws that are holding the bulb carrier in place.
  6. Dodge Durango 2004 Tail Light Bulb Replacement: paso 6, imagen 1 de 2 Dodge Durango 2004 Tail Light Bulb Replacement: paso 6, imagen 2 de 2
    • Remove the bulb holder piece from the tail light by gently pulling it up.
  7. Dodge Durango 2004 Tail Light Bulb Replacement: paso 7, imagen 1 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 7, imagen 2 de 3 Dodge Durango 2004 Tail Light Bulb Replacement: paso 7, imagen 3 de 3
    • Remove the defective bulb by pulling it up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 980
