Saltar al contenido principal
Dissasembling Nokia 8290 Charging Port
Qué necesitas
  1. Dissasembling Nokia 8290 Charging Port, Front Cover: paso 1, imagen 1 de 3 Dissasembling Nokia 8290 Charging Port, Front Cover: paso 1, imagen 2 de 3 Dissasembling Nokia 8290 Charging Port, Front Cover: paso 1, imagen 3 de 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: paso 2, imagen 1 de 3 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: paso 2, imagen 2 de 3 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: paso 2, imagen 3 de 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Dissasembling Nokia 8290 Charging Port: paso 3, imagen 1 de 3 Dissasembling Nokia 8290 Charging Port: paso 3, imagen 2 de 3 Dissasembling Nokia 8290 Charging Port: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to remove the indicated part.
    • The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm.
  4. Dissasembling Nokia 8290 Charging Port: paso 4, imagen 1 de 3 Dissasembling Nokia 8290 Charging Port: paso 4, imagen 2 de 3 Dissasembling Nokia 8290 Charging Port: paso 4, imagen 3 de 3
    • There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well.
    • The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm.
  5. Dissasembling Nokia 8290 Charging Port: paso 5, imagen 1 de 3 Dissasembling Nokia 8290 Charging Port: paso 5, imagen 2 de 3 Dissasembling Nokia 8290 Charging Port: paso 5, imagen 3 de 3
    • After removing the two parts, locate the charging port.
    • Use tweezers to remove the charging port.
Conclusión
Equipo
Clemson, Team 15-3, Benson Fall 2012 Miembro de Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 432
