Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
NOTE: This guide is used for training purposes only. Do not use this guide for repair. For the official guide, follow this link.
Prerequisite-only guide for detaching the display assembly for access to the iPhone 11 internals.
  1. To access the screws in the following step, tilt the display by slightly lifting its lower edge. Be careful not to strain or tear the display cables.
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  2. Remove the bracket.
    • Remove the bracket.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board. Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  5. Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket. Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket.
    • Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket.
  6. Remove the bracket.
  7. Use a spudger or a fingernail to disconnect the LCD panel cable connector. Disconnect the digitizer connector next to it. Disconnect the digitizer connector next to it.
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  8. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  9. Remove the display assembly.
Linea de Meta
Arthur Shi
Miembro Desde 03/01/18
139,046 Reputación
388 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
131 Miembros
13,426 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 112
