Saltar al contenido principal
Dismountable Hand Blender
Qué necesitas
  1. Dismountable Hand Blender, Dismountable Hand Blender: paso 1, imagen 1 de 1
    • Finding and fixing the problem is a cinch!
    • Disassembling the mixer is very destructive!
    • This appliance is a clear example of planned obsolescence since a worn (carbon) brush makes it fit for the trash.
    • If the fault is in the electronic module, clever cutting can make an acceptable repair possible as shown in this ElectroMax video.
  2. Dismountable Hand Blender: paso 2, imagen 1 de 3 Dismountable Hand Blender: paso 2, imagen 2 de 3 Dismountable Hand Blender: paso 2, imagen 3 de 3
    • The speed control knob is easy to disassemble by inserting a knife blade under the graduated circle and prying it up.
    • There are three obstacles to the removal of the motor and electronics module from this mixer:
    • The entire motor block enclosure is firmly secured with adhesive.
    • This motor bearing fastener acts as a circular mount.
    • This plunger system fastener is a second circular mount.
    • I do not see a way around any of these three issues without a certain amount of "destruction".
  3. Dismountable Hand Blender: paso 3, imagen 1 de 1
    • One of the two leads has broken off. Possibly made fragile by improper assembly?
    • Correctly resoldering the lead lets the motor operate normally again.
Conclusión
We do need to cut the shell off the mixer, which makes salvaging this part difficult.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Louis Possoz
Miembro Desde 01/10/15
435 Reputación
3 Guías creadas
Equipo
Repair Café Louvain-la-Neuve Miembro de Repair Café Louvain-la-Neuve
Local Repair Groups
2 Miembros
7 Guías creadas
Un comentario
pourquoi acheter du matériel pro si on ne peut pas le réparer
laurencedelanoue - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 49
Ultimos 30 días: 175
Todo El Tiempo: 14,835
