Saltar al contenido principal
Disc Brake Shimano BR-M445 Brake Pads Replacement
  1. Disc Brake Shimano BR-M445 Brake Pads Replacement, Brake pads: paso 1, imagen 1 de 2 Disc Brake Shimano BR-M445 Brake Pads Replacement, Brake pads: paso 1, imagen 2 de 2
    • Disconnect the hub dynamo connector
  2. Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove the front wheel: paso 2, imagen 1 de 2 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove the front wheel: paso 2, imagen 2 de 2
    • Loosen the clamping screw with 4mm Allen key / Allen and remove the front wheel from the fork.
  3. Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: paso 3, imagen 1 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: paso 3, imagen 2 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: paso 3, imagen 3 de 3
    • Press the cotter pin together with the pointed pliers at the ends and pull out.
  4. Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: paso 4, imagen 1 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: paso 4, imagen 2 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: paso 4, imagen 3 de 3
    • Push the squeaky brake pads out with the needle nose pliers. (For heavily worn brake pads, push the brake pistons outwards).
  5. Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert new brake pads: paso 5, imagen 1 de 2 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert new brake pads: paso 5, imagen 2 de 2
    • Insert the new brake pads together with the spring into the caliper.
  6. Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: paso 6, imagen 1 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: paso 6, imagen 2 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: paso 6, imagen 3 de 3
    • Insert the new split pin and gently press the ends apart with the needle nose pliers.
  7. Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: paso 7, imagen 1 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: paso 7, imagen 2 de 3 Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: paso 7, imagen 3 de 3
    • Insert the front wheel into the fork and tighten the axle bolt with the 4mm Allen key / Allen key.
    • Test concentricity and dynamo.
Conclusión
Repeat the steps in order to reassemble your device.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Froebel Christian
Miembro Desde 02/02/16
447 Reputación
2 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 119
19,521 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 4,622
