Introducción
How do I get the housing of the Loglink PA0085 Mobile Extra Battery 2200 mAH apart to remove battery and circuitry
Qué necesitas
Insert small screwdriver into gap between the two shell halves on one of the three tabs and pry off. Photos should only give clues for the position and shape of the tabs! Carefully fold away housing halves, note rear tabs
Gently pry wire with spring at negative pole down out of plastic tab and lift. Circuit hangs on the wire and tilts up, pull out
Repeat the steps in order to reassemble your device.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
