Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Need to disassemble your Nintendo 64 but don’t have the special tools? Follow this guide to remove the protective barrier and gain access to the motherboard using everyday items.
Herramientas
Partes
No se especificaron partes.
  1. You will need a kitchen lighter and a plastic pen shell, and you will want to do this outdoors to allow the plastic the burn into the air instead of trapping it in a room. Heat the tip of the empty pen shell until it melts into a glob.
    • You will need a kitchen lighter and a plastic pen shell, and you will want to do this outdoors to allow the plastic the burn into the air instead of trapping it in a room. Heat the tip of the empty pen shell until it melts into a glob.
  2. Stick the pen into one of the 6 holes on the bottom of the Nintendo 64. When it reaches the screw, press forcefully for about three seconds and then let go.
    • Stick the pen into one of the 6 holes on the bottom of the Nintendo 64. When it reaches the screw, press forcefully for about three seconds and then let go.
    • TIP: The circled hole has the smallest inner diameter, so if you mold your pen with this hole, you can remove the others without remolding if you are careful not to strip it.
  3. Allow the pen to reform and solidify around the screw for 4 to 5 minutes. If done correctly, the pen will mold completely around the specialized screw and grip it so that it can be twisted out.
    • Allow the pen to reform and solidify around the screw for 4 to 5 minutes. If done correctly, the pen will mold completely around the specialized screw and grip it so that it can be twisted out.
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. Grip the pen and, pushing down forcefully, begin to twist it loose (to the left) as if you were using an actual screwdriver. The screw should  come out with the pen as shown  in the picture if done flawlessly. If not, you can still manage to get the screw out without it molding completely.
    • Grip the pen and, pushing down forcefully, begin to twist it loose (to the left) as if you were using an actual screwdriver. The screw should come out with the pen as shown in the picture if done flawlessly. If not, you can still manage to get the screw out without it molding completely.
  6. Repeat the melting and  re-solidifying process  5 more times for the rest  of the screws, and the console  will be ready to be opened  up for repair.
    • Repeat the melting and re-solidifying process 5 more times for the rest of the screws, and the console will be ready to be opened up for repair.
  7. Open the outer shell of the case if it is not already opened. For a how-to on that, go here.
    • Open the outer shell of the case if it is not already opened. For a how-to on that, go here.
  8. Once the case is off, turn your attention to the silver plate covering the green motherboard underneath. Begin unscrewing the screws connecting the plate to the motherboard.
    • Once the case is off, turn your attention to the silver plate covering the green motherboard underneath. Begin unscrewing the screws connecting the plate to the motherboard.
    • Also remove the two smaller screws on the expansion slot.
  9. The motherboard is now free to be worked on.
    • The motherboard is now free to be worked on.
Conclusión
9 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 18,008
