Saltar al contenido principal
Disassembling the Ematic Genesis
Qué necesitas
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: paso 1, imagen 1 de 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: paso 1, imagen 2 de 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: paso 1, imagen 3 de 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: paso 2, imagen 1 de 3 Disassembling the Ematic Genesis: paso 2, imagen 2 de 3 Disassembling the Ematic Genesis: paso 2, imagen 3 de 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: paso 3, imagen 1 de 1
    • Remove back plate from screen plate and lay both down flat next to each other.
Conclusión
Justin Rohrman
Miembro Desde 03/23/15
745 Reputación
6 Guías creadas
Equipo
Baylor, Team 4-3, Williams Spring 2015 Miembro de Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 318
