Saltar al contenido principal
Disassembling the Circuit Board
Qué necesitas
  1. Disassembling the Circuit Board, Cracking the Case: paso 1, imagen 1 de 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Disassembling the Circuit Board: paso 2, imagen 1 de 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Disassembling the Circuit Board: paso 3, imagen 1 de 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Disassembling the Circuit Board: paso 4, imagen 1 de 2 Disassembling the Circuit Board: paso 4, imagen 2 de 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Disassembling the Circuit Board: paso 5, imagen 1 de 3 Disassembling the Circuit Board: paso 5, imagen 2 de 3 Disassembling the Circuit Board: paso 5, imagen 3 de 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. Disassembling the Circuit Board: paso 6, imagen 1 de 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. Disassembling the Circuit Board: paso 7, imagen 1 de 2 Disassembling the Circuit Board: paso 7, imagen 2 de 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. Disassembling the Circuit Board, Circuit Board: paso 8, imagen 1 de 2 Disassembling the Circuit Board, Circuit Board: paso 8, imagen 2 de 2
    • Remove the three 1 cm T-10 Torx screws.
  9. Disassembling the Circuit Board: paso 9, imagen 1 de 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. Disassembling the Circuit Board: paso 10, imagen 1 de 2 Disassembling the Circuit Board: paso 10, imagen 2 de 2
    • Pull the white wire out of the hot glue.
  11. Disassembling the Circuit Board: paso 11, imagen 1 de 3 Disassembling the Circuit Board: paso 11, imagen 2 de 3 Disassembling the Circuit Board: paso 11, imagen 3 de 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. Disassembling the Circuit Board: paso 12, imagen 1 de 3 Disassembling the Circuit Board: paso 12, imagen 2 de 3 Disassembling the Circuit Board: paso 12, imagen 3 de 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
Conclusión
To reassemble your device, follow these steps in reverse order.
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 9-28, Maness Winter 2014 Miembro de Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 26
Todo El Tiempo: 4,660
