Saltar al contenido principal
Disassembling of Wahl Lithium Ion Trimmer
Qué necesitas
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: paso 1, imagen 1 de 2 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: paso 1, imagen 2 de 2
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: paso 2, imagen 1 de 1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: paso 3, imagen 1 de 2 Disassembling of Wahl Lithium Ion Trimmer: paso 3, imagen 2 de 2
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Conclusión
12 personas más completaron esta guía.
nathan
Miembro Desde 10/22/13
1,410 Reputación
6 Guías creadas
3 comentarios
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Contestar
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Contestar
Thanks…worked well.
Magpie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 161
Todo El Tiempo: 43,912
