Saltar al contenido principal
Disassembling iRobot Roomba 551 Bottom Plate
Qué necesitas
  1. Disassembling iRobot Roomba 551 Bottom Plate, Side Brush: paso 1, imagen 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. Disassembling iRobot Roomba 551 Bottom Plate: paso 2, imagen 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Disassembling iRobot Roomba 551 Bottom Plate: paso 3, imagen 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. Disassembling iRobot Roomba 551 Bottom Plate, Bottom Plate: paso 4, imagen 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Disassembling iRobot Roomba 551 Bottom Plate: paso 5, imagen 1 de 2 Disassembling iRobot Roomba 551 Bottom Plate: paso 5, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Disassembling iRobot Roomba 551 Bottom Plate: paso 6, imagen 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Conclusión
Equipo
Cal Poly, Team 13-14, Regan Winter 2014 Miembro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 2,360
