Introducción
Remove your access door to replace RAM chips or to open the case of your iMac.
Qué necesitas
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw PH#2 in the center of the access door.
Remove the access door from your iMac.
14 personas más completaron esta guía.
