Saltar al contenido principal
Disassembling Xbox 360 E Top Panel
Qué necesitas
  1. Disassembling Xbox 360 E Top Panel, Top Panel: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Top Panel: paso 2, imagen 1 de 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Top Panel: paso 3, imagen 1 de 3 Disassembling Xbox 360 E Top Panel: paso 3, imagen 2 de 3 Disassembling Xbox 360 E Top Panel: paso 3, imagen 3 de 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
Conclusión
4 personas más completaron esta guía.
Jennifer
Miembro Desde 02/02/14
1,915 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-11, Amido Winter 2014 Miembro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Miembros
43 Guías creadas
Un comentario
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 46
Todo El Tiempo: 2,521
