Saltar al contenido principal
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
Qué necesitas
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: paso 1, imagen 1 de 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: paso 1, imagen 2 de 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: paso 1, imagen 3 de 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 2, imagen 1 de 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 2, imagen 2 de 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: paso 3, imagen 1 de 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 4, imagen 1 de 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 4, imagen 2 de 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 4, imagen 3 de 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: paso 5, imagen 1 de 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: paso 5, imagen 2 de 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: paso 6, imagen 1 de 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: paso 6, imagen 2 de 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 7, imagen 1 de 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: paso 8, imagen 1 de 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: paso 8, imagen 2 de 2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: paso 9, imagen 1 de 1
    • Remove both screws holding the retaining plate with the logic board.
Conclusión
Gaetan
Miembro Desde 12/26/12
9,577 Reputación
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,027
