Saltar al contenido principal
Disassembling Western Digital Essentials HD LED Light conducting plastic pieces
Qué necesitas
  1. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: paso 1, imagen 1 de 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: paso 1, imagen 2 de 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: paso 1, imagen 3 de 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: paso 2, imagen 1 de 2 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: paso 2, imagen 2 de 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, LED Light conducting plastic pieces: paso 3, imagen 1 de 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: paso 4, imagen 1 de 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: paso 4, imagen 2 de 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: paso 4, imagen 3 de 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
Conclusión
Gaetan
Miembro Desde 12/26/12
9,613 Reputación
18 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,205
