Este desmontaje no es una guía de reparación. Para reparar tu Oregon Scientific Ultra Thin Weather Station, utiliza nuestros manuales de servicio .
  1. Weather Box, front side
    • Weather Box, front side
  2. Rear side Rear side Rear side
    • Rear side
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
  5. After plastic screen removed, it can see the screws. With a small screw driver, take them off. There are eight screws. With a small screw driver, take them off. There are eight screws.
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
  6. After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  7. Internal view Internal view Internal view
    • Internal view
Andres
Miembro Desde 14/11/13
110 Reputación
1 Guía escrita
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Contestar
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
I lost the the sound on this demo. Does anyone else have the same problem?
Sheila McWilliams - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 10
Últimos 30 Días: 31
Todo El Tiempo: 2,025
