Saltar al contenido principal
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
Qué necesitas
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: paso 1, imagen 1 de 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 2, imagen 1 de 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 2, imagen 2 de 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 3, imagen 1 de 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 3, imagen 2 de 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 4, imagen 1 de 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 5, imagen 1 de 1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 6, imagen 1 de 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: paso 7, imagen 1 de 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
Conclusión
2 personas más completaron esta guía.
Daniel Kresge
Miembro Desde 09/01/15
385 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 8-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Miembros
17 Guías creadas
Un comentario
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 33
Todo El Tiempo: 2,010
