Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Access to Hard Disk Drive
  1. Pry up cover, remove screw.
    • Pry up cover, remove screw.
  2. Remove screws.
    • Remove screws.
  3. Gently pry out to unsnap top plastic housing.
    • Gently pry out to unsnap top plastic housing.
  4. Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
Conclusión
4 personas más completaron esta guía.
WayneG
Miembro Desde 13/05/13
191 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 2,140
