Saltar al contenido principal
Disassembling Toshiba A1304T Front Cover
Qué necesitas
  1. Disassembling Toshiba A1304T Front Cover, Front Cover: paso 1, imagen 1 de 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Disassembling Toshiba A1304T Front Cover: paso 2, imagen 1 de 2 Disassembling Toshiba A1304T Front Cover: paso 2, imagen 2 de 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Disassembling Toshiba A1304T Front Cover: paso 3, imagen 1 de 2 Disassembling Toshiba A1304T Front Cover: paso 3, imagen 2 de 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Conclusión
Christopher
Miembro Desde 04/22/10
90 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-6, Maness Spring 2010 Miembro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,132
