Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to disassemble the Toshiba A1304T.
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
  1. Open the phone so that it matches the photos to the left.
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations. The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  4. Insert the head of a flathead screwdriver into the seam between the front cover and the phone. Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Conclusión
Christopher
Miembro Desde 22/04/10
90 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-6, Maness Spring 2010 Miembro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,042
