Saltar al contenido principal
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
Qué necesitas
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: paso 1, imagen 1 de 1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 2, imagen 1 de 1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 3, imagen 1 de 1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 4, imagen 1 de 1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 5, imagen 1 de 1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 6, imagen 1 de 1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: paso 7, imagen 1 de 1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Conclusión
8 personas más completaron esta guía.
Artem Nikulkov
Miembro Desde 10/22/10
313 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 21,088
