Saltar al contenido principal
Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel
Qué necesitas
  1. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Back Panel: paso 1, imagen 1 de 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 2, imagen 1 de 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 3, imagen 1 de 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Power Button: paso 4, imagen 1 de 1
    • Remove the stylus from the device.
  5. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 5, imagen 1 de 3 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 5, imagen 2 de 3 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 5, imagen 3 de 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
  6. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: paso 6, imagen 1 de 2 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: paso 6, imagen 2 de 2
    • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
    • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
  7. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 7, imagen 1 de 2 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: paso 7, imagen 2 de 2
    • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
Conclusión
Zachary Jeffers
Miembro Desde 10/13/14
412 Reputación
4 Guías creadas
Equipo
Clemson, Team 1-4, Benson Fall 2014 Miembro de Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 308
